What's new in CAMWorks 2023
New features in CAMWorks 2023
- Wire EDM Premium
- Euler Angles Method for 5 Axis Rotary (3+2) Milling
- Additional Probing Cycles and Output Options for Probe Tool
- Tool Selection Logic Based on Flute Length and Feature Depth
- Machine Cavities with VoluMill
- Support for Tapered and Neck Shank Type Tools
- Option to Define Height of 2.5 Axis Milling Islands
Edit the Min Hole Diameter
Linking of LeadinOut Parameters
Support for Tapered and Neck Use
End Direction 2 for islands
Support for Canned Cycle Threading Operations when Cut Type is Reversed
TechDB
Euler Angels
New Probing Cycles
Exclusive Machine Cavities for VoluMill
Considering the correct feeds and speeds
Wire EDM Premium Color Coding
Wire EDM Premium Decals
Wire EDM Premium Form Tool
Wire EDM Premium on Contour Features
Wire EDM Premium Variable Land
