CAMWorks is the only CAM system that is 100% compatible with SOLIDWORKS CAM!
SOLIDWORKS® CAM allows users to integrate design and manufacturing processes in one system to avoid downstream delays and rework cost, helping organizations in bringing high quality products faster to market. Manufacturing tasks that had to wait until a design was complete can now be performed concurrently with the design process.
The solution is powered by CAMWorks. The SOLIDWORKS CAM rules-based technology enables you to integrate design and manufacturing in one application, connecting design and manufacturing teams through a common software tool and 3D model.
SOLIDWORKS CAM Standard
SOLIDWORKS CAM Standard lets you quickly program individual milled parts and configurations without leaving the SOLIDWORKS 3D CAD environment. You have full access to defining rules within SOLIDWORKS CAM to create and build to your company standards, as well as Tolerance-Based Machining (TBM).
SOLIDWORKS CAM Professional
SOLIDWORKS CAM Professional builds on the capabilities of SOLIDWORKS CAM Standard with increased programming capabilities. The additional features include High-Speed Machining (HSM), configurations, assembly machining, turning, and 3+2 programming to drive four- and five-axis machines.
SOLIDWORKS Machinist Standard
SOLIDWORKS Machinist Standard provides all the functionality found in SOLIDWORKS CAM Standard plus a Part only modeling environment allowing you to work seamlessly with SOLIDWORKS Part files and import several neutral file formats. This connectivity makes easy to work with customers and vendors to collaborate on the manufacturing process.
SOLIDWORKS Machinist Professional
SOLIDWORKS Machinist Professional provides SOLIDWORKS CAM Professional capabilities with SOLIDWORKS Parts and Assemblies to allow the user the ability to import and design fixtures and other manufacturing components used in the machining process. By using Assembly mode in SOLIDWORKS CAM Professional, automatic toolpath clipping can be used to ensure your programs do not collide with custom fixtures or vises.
